1993 camaro help
Old Jan 2, 2010 | 03:59 PM
hotzz90's Avatar
Default 1993 camaro help
got a 1993 camaro and needs just a little work.
i have a few questions about what is happening, not sure...
when i back out of my driveway and turn sharp to get onto the road it feels really bumby, this only happens when i reverse and turn sharp...is this my front struts? and and suggestions on good/decent priced ones?
also, i have a hole in the exaust, any good places to get new and good pipes?
and my headliner is starting to sag, once again, any good sites to get a new one from?
im new to the whole camaro scene, so any help will be greatly thanked! thanks a lot!
Old Jan 2, 2010 | 04:31 PM
check the outer tie rod ends. jack up the front so the tires are pretty much off the ground then put some jack stands or if u have some tires on rims stick some under the car so it can t fall on ya. have someone bounce the steering wheel back and forth. look at the tie rod end joints at each side by the tires. ull see if theres play in the tie rod ball joint. check and see what summit is charging for what u can afford then look around and see if u can save any. quality is money. exhaust,,, check out magnaflows cat back and see if there something u would like.
stupifyd69
Jun 29, 2015 11:30 AM
Josh22
Jul 12, 2008 01:40 PM
sl1foru
Oct 21, 2007 05:30 PM
Slimbo
May 26, 2006 08:33 PM
