Door compatibility
Would 1986 IROC or Z-28 doors fit cleanly onto an RS? The kid I bought my RS from put an IROC hood on, and it doesn't match up quite right. I have the original hood which need some cleanup before it can be reinstalled, but the doors of the car are pretty rotted out on the bottom, and I just figure installing salvaged doors in better shape would result in a tigher fit than trying to repair the rot. I've been looking around, and most parts I see are either off of an IROC or Z28, so would they fit (almost) perfectly?
You should be able to adjust the hood near the springs, see if the bolts can slide in their positions. (instead of being a bolt through a circlular hole, it's probly an oval hole, to allow adjustments)
Also, I don't see why they won't match up perfectly. I don't know if you'll need shims like on older models, but I reckon it will work perfectly.
