Where to find RPO Codes?
Old May 9, 2009 | 07:56 AM
Quinny's Avatar
Default Where to find RPO Codes?
Where would the broadcast sheet or RPO code list be in an 86 Z28? I want to go through the codes and see what it got, hopefully limited slip diff.
Old May 9, 2009 | 08:05 AM
there usually in the glove box.
Old May 9, 2009 | 08:22 AM
blackz87's Avatar
Under the console lid if they have not been removed, otherwise you are SOL. Limited Slip RPO is G80.
Old May 9, 2009 | 08:50 AM
Quinny's Avatar
Thanks guys.
If they are not there, is there any way of finding out what options it has? I guess GM would know if I gave them the VIN number...
Old May 9, 2009 | 08:27 PM
blackz87's Avatar
Originally Posted by Quinny
Thanks guys.
GM deleted all the VIN information including RPO options from the dealers data base on most cars that are over 10years old. You can try your local dealer, but don't expect any info.
Old May 10, 2009 | 01:36 AM
Quinny's Avatar
The RPO codes aren't there, so I guess I am out of luck. Oh well, doesn't matter anyway...
Old May 12, 2009 | 09:55 PM
chadriley5's Avatar
Default rpo
in my 92 rs they are in the lockable compartment in the trunk
Old May 17, 2009 | 04:39 PM
mighty mike's Avatar
as chad said 90-92 they put them in the rear lockable compartment. and if ur lucky there is a build sheet in the spare tire compartment
bezerker
Feb 2, 2009 12:23 PM
redchair2000
Apr 24, 2008 08:52 AM
97rsturbocamaro
Jan 12, 2008 10:11 PM
smithdjr
82-92 V8 Tech
Oct 24, 2007 11:25 AM
shnormo
Feb 8, 2007 02:43 PM
