what can this be ?????
Old May 12, 2007 | 03:00 AM
posando's Avatar
Default what can this be ?????
hey guys, on 4/15/07 i bought a 86 camaro Z28, it has a5.0L 305 TPI and i think i have a serious problem, it looks like some engine oil is going into my radiator, ialready cheked the engine and tranny oil ant they look prety clean, it's just the waterin the radiator that lookskinda like coffe with creamer.what doyou guys think is my problem?please help
Old May 12, 2007 | 11:39 AM
vampyrico's Avatar
Default RE: what can this be ?????
flush your coolant system. oil doesnt mix too well with water. so that probably not what it is. just old dirty coolant/water. get of all of it and put in some fresh stuff. if problem persists then it may be somethin a little more serious. but i doubt it.
Old May 12, 2007 | 01:49 PM
posando's Avatar
ok, i took this out of the coolant resivoir, here is a pic to show you what i'm talking about.
Old May 12, 2007 | 01:58 PM
Blade's Avatar
June 2007 ROTM
looks like throw up!
nah could just be that the coils havent been cleaned in a while. LONG while. make sure u flushed out the rad good.
Old May 13, 2007 | 05:27 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, i flushed mine, and it looked worse. when i bought the car, it had a leaky rad and water pump, so most of the water would leak out and leave whatever deposits left. i had the garden hose on the intake and let it run for half an hour and i was still getting crud out of it
Old May 14, 2007 | 07:41 PM
posando's Avatar
hey thanks guys!!!! i was starting to get scare, only problem i have right now is that my electric fan dont kick on[sm=boohoo.gif]
Old May 16, 2007 | 11:48 AM
zeus8807's Avatar
if your system is that clogged up the sensor for the fan may be too, not sure where its at on the 305, but you should have one or two sensors the screw into the coolant passages(not sure on the 305), while your flushing it pull them out and clean them off. might solve your problem. if nothing else hardwire the fan to a switch on the inside and straight to the battery or another power source
Old May 17, 2007 | 01:41 AM
posando's Avatar
yeah i'm going to flush the radiator, but would this be a reason for heating up so fast?
Old May 17, 2007 | 08:36 PM
microkid's Avatar
March 2011 ROTM
Technical User
yea, all that nasty stuff in there will make it run hot. i had an issue with my fan not turning on until about 225*. fir now, i just have a switch to the hot wire directly fed in. i plan on getting a solenoid though so the switch doesnt carry the full load as it gets hot. there are ones out there with lower temps programmed in, but my way is the cheapest and easiest way.
Old May 17, 2007 | 09:22 PM
posando's Avatar
well thats a relief, BTW: i bought a new fan relay, and i think i'm gona buy new 180 degree t-stat and temperature switch.
