what cam?
Old Jun 16, 2007 | 09:03 AM
tourville's Avatar
Default what cam?
First off this is the first time i have been on this site, My name is Tom and i have a 1991 RS Camaro, It had a v6 and i swapped a 350TPI/700R4 combo in it. Aftermarket parts are holley throttle body, slp runners, it has a shift kit and a high rev torque converter also. Over this comming up winter i would like to put a mild cam in the car, but not sure where to start looking. I do not plan on changing the heads this winter, maybe next winter i will not sure though. Im not looking for anything crazy. I like the cam sound and will obviously change the springs and most likly timing chain/gears while im down there. Any suggestions on where to start looking and what needs to be done in order for my car to take a mild cam? I have tuning equipment so i will not have to worry about bringing the car somehwere to get tuned.
Thanks for your time!
heres a couple pics of my car
Old Jun 16, 2007 | 09:16 AM
tourville's Avatar
Default RE: what cam?
Also forgot to state that the engine 350/700r4 came out of a 1987 GTA, i upgraded the wiringharness + cpu to a speed density. Not sure if i have to make sure the cam has to match up to the 87 or if all cams will fit in all engines... I do know that the 87 transmission mounted speed sensor is bigger than the 91 speed sensor therefore i had to buy an 87 speed sensor and use the 87 connector matched on the 91 harness[/align]
Old Jun 16, 2007 | 09:32 AM
Celticsfan's Avatar
off topic but, im from TGO, whats up with that site? Been down since yesterday morning....
