universal fuel pressure regulator on a tpi?
Old Mar 29, 2007 | 11:50 PM
Shmack2004's Avatar
Default universal fuel pressure regulator on a tpi?
i have a universal fuel pressure regulator and i was wondering how i can put it on my tpi engine?
the factory fuel pressure regulator is mounted on the fuel railand mine take hoses to it.
Old Mar 30, 2007 | 01:10 PM
Default RE: universal fuel pressure regulator on a tpi?
Does not seem to be very universal. You should avoid chopping up the fuel system, if at all possible.
Old Mar 30, 2007 | 09:03 PM
coprunr's Avatar
also on those cars the fuel pressure regulator is on the fuel rail , so adding a regulator in front of it will do nothing because the one on the rail will regulate the prssure in the rail. so even if you put a universal regulator in the fuel line , the one on the rail will still regulate pressure back to stock pressure.
Old Mar 30, 2007 | 10:48 PM
Shmack2004's Avatar
i found some adaptors in the package that said TPI on them and they are made to fit one the fuel rail in place of the stock fps. i put it on and it worked fine.
royco95
Aug 2, 2015 10:25 AM
carguylt1
Feb 20, 2011 10:22 AM
Kendagenius
Aug 13, 2010 08:34 AM
Braelay
Jul 15, 2006 08:59 PM
HURSTLT1
Dec 26, 2005 11:18 PM
