trouble finding a performance ignition
Old 01-28-2010, 06:15 PM
Rcing101's Avatar
Default trouble finding a performance ignition
So I have an 86 Z28 305 TPI. I rebuilt the motor, and am getting to drop it back in. Figured I would put a new ignition system in. But I am having trouble finding a 7-pin Ignition Control Module. I found it in Accel. I would much rather go with a MSD, but I just can't find em. Anyone have any advice? Any other manufacturers you had good luck with? Its just a street machine with a set of Headers, Flowmaster 3 inch exhaust, and B&M Ratchet shifter. Thank you.
Old 01-28-2010, 08:01 PM
microkid's Avatar
March 2011 ROTM
Technical User
are you looking for a performance ignition module, the one that goes under the cap in the distributor? the only one i am finding aftermarket for the 7 pin is the accel unit. i cant think of any other companies that offer them, it is a nearly 25 year old car. i had the same engine in my car, but it is the 4 pin. i just want to make sure, but you have visually checked that its the 7 pin? the only other option would be to replace the distributor to use the 4 pin
Old 01-31-2010, 11:21 AM
Rcing101's Avatar
Yes, the module under the distributor. Its definitely not a 4-pin. One side has the smaller prongs, and the other has 2 bigger ones. But when I counted them a few months ago, I though I counted like 5 all together, but I could be wrong.
Old 02-03-2010, 09:57 AM
LETSROC's Avatar
Try this web site or give them a call. They are very good www.hawksthirdgenparts.com
Old 02-04-2010, 07:35 PM
microkid's Avatar
March 2011 ROTM
Technical User
if you can, take a picture. i might be able to help you more
Panther7011
07-29-2014 11:04 AM
stenny
70-81 V8 Tech
09-15-2012 07:40 PM
nmallory56
08-27-2009 10:13 PM
Crayola
12-21-2008 07:43 PM
Spartan66
03-24-2008 11:37 AM
Quick Reply: trouble finding a performance ignition
