tricky situation help???
Old Apr 18, 2012 | 10:10 PM
87 camaro z28's Avatar
Default tricky situation help???
My 87 z28 305 had been acting up come to find it had a misfire. I found the cylinder took out the spark plug and it had oily deposits so I changed it and made sure the wires had current and they did the cylinder still misfired seems like its dead im running on 7 cylinders I figured it be the piston rings or valve seals bit my oil consumption is normal and all other cylinders are working fine there is a little puff of smoke when starting the car but that's due ti a coolant leak and if it was the rings or valve seals my oil level would be much lower. Im at a dead end help please? ???
Old Apr 18, 2012 | 10:57 PM
Camambro's Avatar
April 2012 ROTM
Burnt valve
Old Apr 18, 2012 | 11:01 PM
How can you troubleshoot for that?
Old Apr 18, 2012 | 11:05 PM
Camambro's Avatar
April 2012 ROTM
Idk when that happened to me I just opened it up and looked
Old Apr 18, 2012 | 11:50 PM
Around how much is it on repair costs? ??
Old Apr 19, 2012 | 12:17 AM
oldman9's Avatar
That would depend on a few things, but mostly if your going to be doing most of the work yourself.
Old Apr 19, 2012 | 12:47 AM
Camambro's Avatar
April 2012 ROTM
yeah if you do it yourself its around 150
Old Apr 19, 2012 | 07:18 AM
I had heard if a test to hold a towel on the tailpipes and if it was being vacuumed in it was the burnt valve I attempted it this morning after starting it up but it blew out the exhaust as it should????
Old Apr 19, 2012 | 08:23 AM
Give the engine a compression test and a leak down test. Google it if you don't know how.
Old Apr 19, 2012 | 08:33 AM
Camambro's Avatar
April 2012 ROTM
What he said^^^
