Transmission swap
Old Mar 24, 2010 | 05:18 PM
Camaro86IrocZ28's Avatar
Question Transmission swap
I bought a 1986 camaro last year pretty cheap and it basically is a carbed set-up in a fuel injected car. Now there is no computer so I had to wire somethings in but that aside I was thinking of getting a 400 trans. However my friend is telling me not to and rebuild a 350 trans that he give me for 75 bucks and I already do have the rebuild kit for it. So my question is which should I go for?
Old Mar 24, 2010 | 05:50 PM
Jr. Mechanic's Avatar
August 2009 ROTM
What's wrong with the current transmission?
Old Mar 24, 2010 | 06:53 PM
The 700 r4 is slippin bad and just havent had luck with 700s
Old Mar 24, 2010 | 07:52 PM
djs383's Avatar
It will be alot cheaper to go with the 700R4. If built even remotely well they handle above stock power. Most problems with the 700, is that the TV cable is not properly set and that causes them to slip pre-maturely. You said its a carb motor in an FI car which means it was re-connected during that swap. Most people never get the correct brackets and adapters to get the geometry and adjustment correct. Check the overall length of the 700R4 vs. TH350 vs TH400. I believe they are all different lengths, requiring a driveshaft modification.
Old Mar 24, 2010 | 07:56 PM
djs383's Avatar
I know this is for a older chevelle, but gives pretty good information on transmission dimensions. http://www.chevyhiperformance.com/te...ech/index.html
Old Mar 25, 2010 | 12:05 AM
thanks man any other suggestions on transmission swaps? only cause I'm working on a 383 just want things to work right lol.
Old Mar 25, 2010 | 07:36 PM
microkid's Avatar
March 2011 ROTM
Technical User
someone was making a swap kit that included the driveshaft, cross member, brackets and cables, and everything else needed. summit racing might still carry it, but it was not cheap
Old Mar 25, 2010 | 09:54 PM
carguy68ssrs's Avatar
I would stick with 700r4 cause you get overdrive and then you can run lower rear end gears but still be able to cruise at descent rpm's on freeway. 400's alot of trans for just 383. Like DJ says make sure the tv cable is adjusted right
Old Mar 26, 2010 | 11:02 PM
August 2009 ROTM
Swapping to a TH350/400 is plain stupid unless it's an all out drag car, even then it doesn't make a whole lot of sense. For what it's going to cost for the new transmission, a drive shaft, torque arm relocation cross member, and the shifter conversion, you could have the 700R4 built to hold 600hp easily. Then you can still get on the interstate after a day at the track and pull 20mpg.
Just IMHO
Old Mar 28, 2010 | 11:00 AM
Hm glad I decided to ask people before I started on the swap
thanks guys
Victor Lamb
May 1, 2013 12:13 AM
89CamaroGuy
Sep 13, 2011 11:43 AM
dm121204
Aug 2, 2009 12:27 PM
willef99v6
Jul 29, 2009 01:09 AM
srich1207
Apr 7, 2008 09:24 PM
