tap tap tap hope there isn't a crack
Old 04-29-2007 | 07:47 PM
zachyfarms's Avatar
Default tap tap tap hope there isn't a crack
Just baught 84 z28 with 305... before buying i noticed a tapping noise but one that sounded to be a simple thing... after driving 200 miles home i checked things out found all the driver side spark plugs to be very loose hand turn loose i figured that was the noise i was hearing( great yeah). nope it is definately drivers side 1 and 3 cylander area. can an exhaust gasket blow and make a noise that almost sounds like valve tapping??? i know i may be stretching that one but im wishing for something simple.. if i have the car in park and rev it, it doesn't or barely taps it only when under load that it taps.... any suggestions... ,
Old 04-29-2007 | 08:08 PM
74454bb's Avatar
May 2007 ROTM
Default RE: tap tap tap hope there isn't a crack
Could be an exhaust manifold gasket. they make a tapping sound when they blow.
Old 04-30-2007 | 01:08 AM
94Z28SHAKER's Avatar
either that or a loose rocker nut, if its still there after you change the gasket, take off the rocker covers and find the tap, tighten the rocker nut slightly until the tap goes away, should only take 1/8th of a turn, if that, so dont go crazy tightening them, do it cautiously, and good luck.
ps. if its still there after all that, you may have any number of bad things wrong in the bottom end of the motor.
Old 04-30-2007 | 01:27 AM
GRIFF's Avatar
Does it make the noise at idle? Did you try higher octane fuel?
Old 04-30-2007 | 02:22 AM
MadMikeZ28's Avatar
You may find that there are no gaskets on the exhaust manifolds. Sometimes the factory never put them in there. It could also be a cracked exhaust manifold. It may be broke under the shield for the heat riser tube. Look around and see if there are any blackened areas from exhaust leaks
Old 05-02-2007 | 09:00 PM
zachyfarms's Avatar
Thanks for the help noise is gone and i performed both process on the engine it runs a lot better too.
MN79Camaro
10-16-2011 11:13 PM
boostedzx3
08-26-2009 11:23 AM
smorgan907
05-17-2009 08:15 PM
350rs
07-08-2007 09:26 PM
Quick Reply: tap tap tap hope there isn't a crack
