Stupid Squeaky Belt
![Angry](https://camaroforums.com/forum/images/icons/icon8.gif)
Hey guys, does anyone know of any tricks one can use to stop a squeaking serpintine belt? belt dressing works for awhile then it starts again. is there anything else to try or just get a new one?
Did you ever get it wet with anti-freeze? That can give you a repeat squeaker. You can remove it and clean both sides with brake cleaner and a scrub brush. And clean all the pulleys too. But if it still comes back, you might want to get a new belt. I like using the Goodyear Gatorback belts because the cross-cuts in the ribs makes for less of a tendency to squeak. Actually, I've never had a noisy Gatorback.
hey man, i tried the brake cleaner trick, i saturated a rag with it and with it running wrapped the rag around it and cleaned it good, then gave it a light shot shot of belt dressing. so far so good.
