still having problems
my 91 doesnt seem to be getting any gas but when i took it to the shop the mech said that it was just the starter(which i have had problems with) but 3 days after i got it back it did the same thing. and now it seems like the starter is bad again! whats the deal? someone please help me this is my only mode of transportation!
RE: still having problems
I have no idea what that light "infl rest" means but you might have a manual or a Haynes or Chiltons book. I thought about it somemore and seems like you have a spark problem and not a fuel delivery problem. Look at your serpentine belt for cracks tears or it could be a pulley on that whole sytem is loose and wobbling or something hope this leads you in the right direction ro getting it fixed.
unprovoked air bag?!?!?LOL
i wish i could see that id be all [sm=laughat.gif]
mine blinks for an unusaully long timeat start up but it shouldnt be blinking while your driving thats a problem
as for the engine check your plugs n wires mine was farting an sputtering for a while seemed like it was fuel related till i accidently touched the #5 wire and it arched into my hand. changed them and it runs like a champ now (cept for the oil pressure thing)
hey if your car is going through starters that often try to turn the engine manually at the crank and see if it turns if you have to apply alot of pressure to turn the engine manually the you might have internal problem meaning its starting to seize
