smoking
my camaro smokes all the time cant figure out why it smokes so much i think maybe the carb is pumping to much gas in engine?
What color smoke? Does the smoke smell sweet?
Originally Posted by jimm417
(Post 614766)
Without knowing the color of the smoke or where it is coming from it is just a guessing game. However; if the engine is smoking heavily and still running good, you can probably eliminate a rich fuel mixture. An engine creating as much smoke as you describe from a rich mixture would foul the plugs and run poorly.
Black smoke = rich mixture, misfire, or both. Blue smoke = oil burner, or oil leaking on hot exhaust and burning off. Blue smoke under acceleration = bad rings Blue smoke while coasting = bad valve seals, worn valve guides or valve stems White smoke = coolant getting into combustion chamber, probably due to bad head gasket, cracked head or block, bad intake manifold gasket, etc.. |
Mine smokes white when you first turn it on and when I step on it hard. :( . I doing the valve seals in a two weeks or so
Valve seals are not your problem.
well its a light white smoke and it comes form the exhaust and it smells like the gas isnt burning completely just smells like gasoline
and the car is still pretty fast and it does run kinda funny hard to explain i think it runs this way because the computer isnt hooked up and there is no sensors hooked up and o2 sensor is broken off
also the top radiator hose leaks and one of the gaskets r leaking oil
Were you thinking rings pete?
