Sensors
Old May 31, 2010 | 08:48 AM
RoyBean's Avatar
Default Sensors
Could someone tell me the number and names of sensors on a 1986 IROC Z28?
I would also like to know of a good manual that has a wiring diagram . The manual I have is sorry to say the least.
I like this site. Been reading a lot. Lots of nice rides. Roy
Old May 31, 2010 | 08:40 PM
microkid's Avatar
March 2011 ROTM
Technical User
are you looking for part numbers, or just an amount of sensors? anything in particular? haynes and chiltons manuals both have good wiring diagrams.
Old Jun 1, 2010 | 12:03 AM
RoyBean's Avatar
I have a haynes and it doesn't have a wiring diagram. I shouldn't expext much for $0.99.
I know there is a throttle position switch, air flow sensor,knock sensor. I don't know the name of the switch under the throttle body near the temperture sending unit.
I don't think this engine has a EGR valve. It is just like the older cars with a tube coming out of the valve cover going into the intake.
I'll have to get a good manual. I like to read up on procedures the day before i start on something.
Thanks for the reply.
Old Jun 1, 2010 | 12:37 AM
??? Did you buy your Haynes from a garage sale, or are you not talking about the full manual? The Haynes 3rd gen repair manual has a full wiring diagram on your car. Engine control schematic is in section 10-19, and shows everything you're looking for.
Oh, and yes, your engine does/did have an EGR valve. The tube you're talking about (if you're referring to the passenger side) is a crankcase vent tube, and is normal. Are you thinking of a PCV valve? Yours should be either in the other valve cover, or the intake manifold.
Old Jun 1, 2010 | 05:46 AM
RoyBean's Avatar
I'll get a better manual. Thanks.
dmoneey05
Feb 26, 2012 11:03 AM
Kendagenius
Jun 20, 2010 06:02 PM
steveh3500
Apr 15, 2010 09:37 AM
bidicamaro
Apr 24, 2008 12:10 PM
Lucas
Mar 5, 2008 06:48 PM
