removing engine mounts
Old 05-04-2009 | 04:34 PM
Michael Snyder's Avatar
Default removing engine mounts
i am trying to get the engine mounts out of my 84 Z28 (bushings are shot) and i can seem to get to the nut on the back of the mounting bolts. any tricks out there to getting to them? i was hoping not to have to cut them off.
Old 05-17-2009 | 03:40 PM
mighty mike's Avatar
when i swapped my motor i had to swap my mounts and the only way i could get in there is to remove the lower a arms (just the 2 bolts that go into the body)
Old 05-18-2009 | 12:20 PM
thats what i was afraid of! oh well, i may as well take it all apart and change out the bushings as long as i am in there!
thanks!
mike
Old 05-18-2009 | 07:10 PM
djs383's Avatar
No, you don't have to remove the a-arms! I've done two cars in two days, its not that bad.
1st. get a small led flashlight and insert it into the a-arm/subframe connection to illuminate the whole area well.
2nd. Start on the passenger side. You can use a regular socket to get off the bottom nut, then go throught the "O" shaped hole in the subframe to get at the top two.
3rd. Driver side is a little easier, same drill bottom nut with socket, top two with 15mm wrench though the "O" cutout.
4th. put the inserts in correctly, by mistake i installed them backwards once and couldn't figure out how the motor wouldn't settle on them....stupid
5th. install the bottom nut on passenger side by taping it to the 15mm wrench. I used electrical tape loosely so it could twist to fit the inserted bolt easier, it worked well because the tape was pretty elastic. put a dab of grease and stick the nut to the washer, it should fall out if you can just get it started on the bolt.
6th, wear glasses and try not to swear too much, they will probobly fall of once or twice till you get the hang of it.
Old 05-18-2009 | 07:28 PM
i tried that and #6 didnt go so well
Old 05-19-2009 | 11:32 AM
i'll try to keep a tally on #6 when i try it.
thanks for the process breakdown. that will help a lot!
ozzies 68
03-18-2015 04:51 PM
Luz Hernandez
10-21-2010 07:12 PM
dynarider33
11-01-2008 12:10 PM
got3ofem
10-03-2008 01:12 AM
camarohelp
07-06-2007 06:35 PM
