REAR HATCH HELP
Old Dec 31, 2007 | 04:23 PM
westown's Avatar
Default REAR HATCH HELP
I WENT TO PUT MY NEW LIFT SUPPORTS ON MY HATCH AND FOUND OUT THAT THE PULL DOWN MOTOR ON MY REAR HATCH COMES ON BUT IT DONT PULL THE HATCH DOWN IT DONT MOVE AT ALL SO MY HATCH CANT LOCK WHAT CAN I DO TO LOCK IT OR WILL I HAVE TO GET A COMPLETE ASSEMBLE
Old Dec 31, 2007 | 07:39 PM
blackz87's Avatar
Default RE: REAR HATCH HELP
Try pushing the pull down switch under the brushes with your finger (nothing going to grab it) to raise the pull down. If it is not that, you have bigger problems. Go to Top Down Solutions web site and download the repair and touble shooting instructions. They are also a good source for the parts you will need. These are the only parts that go bad.
1) nylon guides
2) Plastic gear
3) motor & housing if broken
It is no big deal to repair it once you take it apart and see what you need.
Old Apr 10, 2008 | 12:48 PM
westown's Avatar
the hatch motor just stays on it never turns off and it doesnt lock the hatch
Old Apr 10, 2008 | 01:30 PM
blackz87's Avatar
ORIGINAL: westown
Remove the rear panel and disconnect the motor (it will drain the battery). You might have a stripped plastic gear.
Old Apr 10, 2008 | 02:23 PM
westown's Avatar
yeah i did that but i forgot to say i bought a new motor and let me tell you im mad cause those aint cheap but it does the same think with the new motor
Old Apr 10, 2008 | 03:38 PM
blackz87's Avatar
ORIGINAL: westown
You didn't read my other Post on what you need to repair the Hatch. Well good luck.
Old Apr 19, 2008 | 06:25 PM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
check your relay. The tunk is prone to leaking there and you can get corrosion around your wiring and relay. I had the same problem bout a new assembly and then found out the relay got wet and fried
Kraker
Oct 14, 2012 09:15 PM
camaro92rsv8
Sep 1, 2008 03:03 PM
Jeramy
Jan 20, 2008 10:11 AM
rockin85
Aug 27, 2007 05:50 PM
rmsy13
Jan 21, 2007 12:24 AM
