Power Question
Old 08-10-2009, 07:23 AM
blackz87's Avatar
Originally Posted by IROCNeeveeZ28
Alright, what do i need to change to put some steeper gears in?
Whatever route you take it is going to be expensive. Number one, you will need a 3-seriers BW 9-bolt carrier ( source salvage yard / used or limited new from off shore). 3:73 gears and rebuild kit for 9-bolt. Also this NOT a DIY type of job unless you want a screwed up rear. Also, 9-bolt & 10-bolt parts are NOT interchangeable so don't even think about it. If that 2:77 ratio & LSD is not broken leave it alone. My opinion.
Old 08-11-2009, 10:04 PM
Stix80's Avatar
im with black on this the reason i did mine was because a bearing was going out and it was grinding into my pinion
Old 08-11-2009, 10:27 PM
IROCNeeveeZ28's Avatar
Ok thanks for the input. Can't stand the lack of acceleration i get though.
Old 08-12-2009, 11:00 AM
blackz87's Avatar
You need more ponies upfront...Forget a gear change to make you fast..
Old 08-13-2009, 11:16 AM
Well the thread wasn't just mentioning gears, i was also asking about a mild cam, full exhaust, etc. Wondering what kind of potential power numbers i can attempt to achieve on the engine i've got
Jack_M
09-15-2015 11:24 AM
ACEDEAN
09-06-2010 03:46 PM
BoricuaHec01
08-05-2010 04:20 PM
TearsInTheRain
06-23-2007 12:21 AM
Eric89RS
03-24-2007 12:00 AM
Quick Reply: Power Question
