Please HELP! Car sputters under load!
Old 04-06-2011, 07:59 PM
microkid's Avatar
March 2011 ROTM
Technical User
if you can find an ecm at a junkyard for a similar car, you can try it. most junkyards dont charge more than $40 for them (around here at least). pick one up as a just in case. if that doesnt fix the issue, then you know what isnt wrong and can continue looking. does the harness look like its every been cut into before, or if an aftermarket alarm was installed?
Old 04-09-2011, 01:55 PM
GLENN M's Avatar
if something it needs is missing or dead it wont ever run good.you have melted wires and a flickering s.e.s.light.you have a wiring problem its shorting somewhere if i were you i would find it before you have a fire or cause more damage.you should probly buy a new front end wiring harness,or start buy removing yours until you find problem its not hard.first thing i do is take out all aftermarket wiring put it back to stock usally cures most or all problems.
arodrig
03-19-2012 11:42 PM
my71baby
70-81 V8 Tech
22
01-25-2011 02:56 PM
DavidJ1907
09-30-2009 05:47 PM
datboypatrick954
06-21-2009 04:19 PM
luvmysccamaro
05-25-2009 02:32 PM
Quick Reply: Please HELP! Car sputters under load!
