Oil Pressure is everywhere 91 RS 305
Old Nov 4, 2010 | 10:50 AM
jmonda's Avatar
Totally my fault I just realized what I did I meant in the morning when I first start it the car is up around 60 psi. I am so sorry I mistyped. When I am driving the car usually hangs out around 40 PSI. When the car is warm and I am sitting such as in a drive thru it will drop clear down to 20 and under.
I hope that clears it up I am sorry for the confusion. I have an autometer oil pressure gauge on it now.
Old Nov 4, 2010 | 10:57 AM
Ok, that's different! Your cold psi is fine, but dropping as low as it does (close to 0?) when it's hot is an indication of worn rod and/or main bearings. Using a thicker oil will help to boost oil pressure, just be aware of the condition of the engine as it is. Autometer gauges are fine, so based on your statement above, I highly doubt it's a faulty gauge reading.
Old Nov 4, 2010 | 11:04 AM
jmonda's Avatar
Thanks so much Camaro 69
I was planning on using the Rotell 15w40 with a wix oil filter to see if that would help at all. Is this a good idea or should I go with a 20w50?
Old Nov 4, 2010 | 11:20 AM
Do you live in a cold winter climate? With 20w50, you'll have a hell of a time cranking the engine over easily in sub-freezing temps.
Old Nov 4, 2010 | 11:23 AM
jmonda's Avatar
Yeah I am in Northern Missouri and it does get cold in winter
Old Nov 4, 2010 | 11:31 AM
Yeah, then just try the 15w40. The "15" could even be marginal if we get some severe cold (below 0), but winters of late haven't been that bad, and I'm a bit north of you. Gee, I sure miss the times when we used to have 20-30 below zero temps, with 60 below wind chills....not!
Old Nov 4, 2010 | 12:41 PM
jmonda's Avatar
Sounds good I will give it a whirl
Old Nov 4, 2010 | 06:21 PM
torque_is_good's Avatar
20 to 30 below, what's that?
That's why I moved from New England to sunny Florida.
If you guys see 20 degree or less temps I wouldn't suggest 20w anything. 10w-xx is where you need to be
And to the OP, how far below 20 psi does it drop?
Old Nov 4, 2010 | 08:29 PM
microkid's Avatar
March 2011 ROTM
Technical User
those pressures sound good. my engine will run 80 psi when cold, 60 when hot, and drops to about 25psi when idling around 700 rpm. it is a brand new engine though, so with your reading being close, id say youre fine
Old Nov 4, 2010 | 09:01 PM
  #20
^ But...earlier he said it drops to near zero at idle while in gear.
