Misfiring Issue!
Old 06-01-2011 | 07:19 PM
microkid's Avatar
March 2011 ROTM
Technical User
the o2 sensor should be before the collector on the driver side header only. by saying air filters, im assuming its a tpi engine? if so, the o2 wire will be purple. a misadjusted tps and no 02 will cause it to stay in open loop. i dont think it would cause a misfire unless under heavy load. also being in open loop, the timing wont advance as much. do you have an infared temp gun availible?
Old 06-01-2011 | 08:30 PM
StephenS's Avatar
I do not have a temp gun.
The exhaust system was put on about 11 years ago when my dad had the car. It ran fine for him.
I'm gonna change the TPS tomorrow. I need some help adjusting it though. Any recommendations on how i should go through with this?
Old 06-02-2011 | 06:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
its to be set at .45-.50 volts when the throttle is closed, and i think its 4.5 volts at wot. just turn it to get it set correctly. is it a tpi engine?
Old 06-02-2011 | 07:54 PM
StephenS's Avatar
Yes, it is a TPI engine.
Old 06-03-2011 | 06:49 PM
microkid's Avatar
March 2011 ROTM
Technical User
ok, could be injectors. when its running, put your finger on each one, there will be a distinctive clicking feel. that will determine if the electrical part is good, or you can ohm them with an ohm meter. they could also be clogged or partially clogged
Old 06-27-2011 | 01:04 AM
vonda188's Avatar
I have a 96 3.8 six cylinder camaro rs its misfiring on multiple cylinders. I think plug wires may be crossed. I just put a new egr valve in it.
Old 06-28-2011 | 02:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
post in the correct section. thanks
Old 07-15-2011 | 08:04 AM
rusty vango's Avatar
i am constantly amazed at the people who remove parts from their cars and THEN bring them to my shop saying things like"after i put(fill in the blank)on it just wont run right" or some version.and i DO charge extra to reassemble their cars correctly after they give up
JeepGuy12
08-21-2010 06:35 PM
x69x442x
01-09-2009 11:07 AM
camarofreak1990
10-03-2008 02:58 PM
dumbnstupidone
03-23-2008 06:47 PM
94 z28
03-16-2008 11:58 PM
