it is making a grinding sound?
Worn bearings. If your pinion gear bearings are sloppy, the pinion gear will want to climb the ring gear, giving a bad gear mesh. Or, your outer wheel bearings could be worn and putting some up or down force onto the ring gear carrier (which could also have sloppy bearings). You didn't say, but should we guess that you have a lot of miles on the car?
