LB9 specifications?
LB9 specifications?
I'm in the middle of filling out a form on compcams.com for recommending a camshaft- in case I decide to start on some mods to go in the Camaro.
I'm having some trouble filling out all the fields- I don't know absolutely everything about the engine I've got and the intarweb has only been so helpful. :/
Anyways, I need the following information to finish filling it out:
Piston Type
Connecting Rod Type
Cylinder Head Part Number
Head Runner Volume
Intake Valve Size
Exhaust Valve Size
Rocker Arm Ratio
RPM Range - Low & High
My Haynes manual has also been of very little help :/ Perhaps one you guys knows enough to help?
Piston Type
Connecting Rod Type
Head Runner Volume
Intake Valve Size
Exhaust Valve Size
Rocker Arm Ratio
RE: LB9 specifications?
ORIGINAL: Saint Ebony
Piston Type
Connecting Rod Type
Head Runner Volume
Intake Valve Size
Exhaust Valve Size
Rocker Arm Ratio
Piston Type
Connecting Rod Type
Head Runner Volume
Intake Valve Size
Exhaust Valve Size
Rocker Arm Ratio
Flat tops with valve reliefs 9.5:1cr
Stock cast rods
Don't know P/N
1.5 ratio
and as it sits if you have an automatic it will shift around 5000 +/-. Stock small block you don't want to be reving over 6000rpm too long. Get valve float.
Yeah, it's an auto- I figured it was around 4500, 5000, although the low end I was less sure about.
The rocker arm ratio- that's 1.5:1, or...? The form asks for it in x:1 form, so, yeah. >.>
And for the pistons- just for knowledge sake, could I ask ya to explain what the "9.5:1cr" bit means?
Thanks for the help!
Ahh alright then- it asked for compression ratio in another field and it happened to be one thing I did know.
http://www.compcams.com/Information/CamForm/camform.asp
just fer the record~
Awesome, thanks!
Looks like all I still need is the Head Runner volume (unless it is the 58cc you mentioned- times like this I wish I knew more than I do :/)
And I wanted to double check the low end of the RPM range- I wrote in 1500 as a random guess, but I really don't know.
Low end of the rpm range would be determined mostly by the effective range of the intake manifold. Since a lot of "all-around" intakes generally start a little bit off-idle, plugging in 1500 rpm should work fine.
Well crap. I got impatient and submitted with 58cc and wrote in "Idle" as the low end.
Shows me. Ho well, we'll see what kind of a response they give and can correct later on, I think~
