hoods and turbos
hoods and turbos
i found a twin turbo kits on ebay that i've been thinking bout getting but i'm not sure if this all will fit under a ram air hood here is the twin turbo specs
turbo Kit Includes:
T3/T4/T04E Turbo Charger x2
Turbine Turbo Charger
Oil Cooled Only
6 Blade Propeller
May modified to use external or internal wastegate
Suggested for 1.6L to 2.3L engine up to 150-400HP
Compressor Specs: Turbine Specs:
3" compressor Inlet T3 Type Turbine / 11 Blade Type / 2.25" Exducer
3.000" or 76.20mm Major Exhaust Outlet Flange with 5 bolt design
1.988" or 50.50mm Minor Turbine .64 A.R. / 76 Trom
Compressor .50 A.R. / 57 Trim 2.560" or 65.04mm Major
M24 / T4 Compressor Housing
Performance Turbo Manifold w/ External Wastegate Flange
Quality Stainless Steel for Chevy Specific
Uses T3 Turbos and External 35mm/38mm Wastegate
Extreme High Resistance to Heat
Able to Keeps Power Steering and Air Conditioning
Direct Bolt On; Nuts, Gaskets, Bolts Included
38mm External Wastegate (color varies) x2
Utilize 35mm/38mm Flange
V-Band top allows for quick changing of springs
Designed to release gas efficiently / Better Control of Turbo
Nut and Bolts Include
Performance Twin Turbo Intercooler (32" X 5" thickness, 3" inlet)
Direct Bolt-on Replacement
Light Weight Aluminum for Maximum Cooling
Can Hold up to 1k+ CFM
Supports up to 15 Psi
Piping Kit (2x U-Bend + 2x 45 deg + 2x 90 deg + 2x straight pipe)
Quality Aluminum 2.5" Piping
8x Silicone Couplers
16x Stainless Steel T-Bolt Clamps
Turbo Boost Controller (Color Varies)
Made from CNC machined and Anodized Aluminum
1-30 PSI Adjustable Increments
Blow Off Valve
Fully & Easily Adjustable
Prevents premature boost leakage and compressor surge
Capable of high levels of boost without losing boos
Braided 1/8 NPT Turbo Oil Feed Lines x2
1/8 NPT Adapter - male fittings mates with the block
Specially designed inlet adapter regulates the oil flow
3/8 diameter stainless steel braided lines
Length = 36
Turbo Oil Return/Drain Lines x2
Circulates oil to oil pan, only works w/ metal oil pans
Length = 17"
Oil Catch Can Tank (Color Varies)
Quality Aluminum Construction
Indicator Hose Included
Vacuum pressure Sender Adapte
Slim Turbo Timer (Color Varies)
One of the Smallest Turbo Timers in the market
Provides turbo sufficient wind-down time to prevent high levels of oil temperatures
Manual mode allows a preset idling timing from 0 seconds to 10 minutes in increments of 16
Anti-theft protection feature disengages the vehicle if handbrake is depressed without ignition key
turbo Kit Includes:
Oil Cooled Only
6 Blade Propeller
Blow Off Valve
Length = 36
Length = 17"
Don't you mean, "if he builds it, it will come...apart"?
You are going to rebuild the engine at the same time, or at least the upper end aren't you? Putting any kind of boost on an old engine (one that can easily blow a head gasket on it's own when the mileage gets high), is a recipe for failure.
