Help i need calipers!
i picked up a set of mine from a local parts store. you could try to find a store that might be able to order you some. i can advise though, installing the parking brake cable and assembly to them is rather difficult. i had 2 driver side calipers fly apart on my while i was working with them. i suggest having someone install them professionally.
Huh. I never had a problem. The piston shouldn't fly out until it's at full travel, it works on a screw principal because of the Ebrake system.
