Help!!! Cant Read Tire Pressure on door!
Old 07-01-2008, 05:00 PM
black89rs's Avatar
Default RE: Help!!! Cant Read Tire Pressure on door!
if you over/under inflate tires it effects handling, tire life, etc.etc. flowmaster tire pressure is usually done once the tires are warm...........at least i've always known.....i could be wrong
Old 07-01-2008, 05:12 PM
blackz87's Avatar
ORIGINAL: black89rs
Tires pressure & air added when the tires are cold for accurate readings. Hot tires air pressure goes up......
Old 07-01-2008, 05:54 PM
black89rs's Avatar
i stand corrected
Old 07-01-2008, 05:57 PM
I used to race go-karts in a past life, and we would always check pressure after doing some practice hot laps before the race. It does help to keep the hot tire pressures a little more consistant, since tire temperatures (and pressures) can vary from day to day depending on the weather and track temperature. But that's racing, where the slightest variance can make a competitive difference.
That's not so practical for a street car though, unless you carry an air compressor and gauge with you so you can get out of the car at the next red light for a pit-stop.
Old 07-01-2008, 05:59 PM
black89rs's Avatar
lol [:-][&:][8D]
Dappled Apple
01-23-2010 06:53 PM
Z28 Kid
02-07-2008 10:57 PM
aleksandr
11-29-2007 12:03 PM
00camaro00
General Racing/Tech
09-25-2007 12:13 PM
wwotr
01-13-2007 07:21 PM
Quick Reply: Help!!! Cant Read Tire Pressure on door!
