egr solenoid vacuum valve
Old Mar 31, 2009 | 11:39 PM
blue max's Avatar
Default egr solenoid vacuum valve
i just realized that my 89 iroc does not have the egr solenoid vacumm valve installed or the vacuum lines connected. the egr valve on the tpi manifold is connected electric and vacuum. what is the purpose of the solenoid valve. can i remove the entire egr system and do away with this system.
Old Aug 31, 2009 | 10:42 PM
jleugers's Avatar
Default EGR solenoid vacuum source
I too have a 89 IROC and recently experienced the motor struggles to start and wont stay running. Upon investigation, I noticed the back side of the EGR solenoid had an electrical plug disconnected (which I reconnected) but also there is a vacuum connection but no vacuum line insight? Question is where is the vacuum source to connect to (directly below the electrical plug) the solenoid?
Hoping for help
ARROW
Nov 15, 2015 05:38 PM
lightningcruiser
LS Series Tech
Oct 11, 2014 02:17 PM
mab6680
Feb 22, 2012 08:51 PM
KiddCamaro
Apr 12, 2011 07:40 AM
