driver side door hinge
I've looked all over the internet and the cheapest one i found was for 115$. I saw just the bolts on ebay for like 10$ and i dont know if those would work or not. so does anyone know where i can find an upper door hinge for a 91 camaro for less than 100$?
Sure there is. But you need to grind off the old top pins to replace it with new pin/bolts and bushings....like this: Door Hinge Bolts & Bushings
Your other option is to grind off the old hinge and weld the new one on. Yes, the hinges are welded to the doors!
CamarosAreGreat
04-15-2010 08:04 PM
