Can't go past 180kph
Old Jul 10, 2009 | 12:20 PM
MitchellDeMoor's Avatar
Default Can't go past 180kph
I was doing a total restoration on my 1991 Camaro RS. I needed another car to drive in the mean time. Something that didn't have any problems that I could just drive to and from school. I found another 1991 Camaro RS. This one has already had some minor modifications done to it. It had a motor swap and I think it is an L05 350. I could be wrong but if I had to bet on it that is what I would say. I just drive the car and use it as my daily. It has MSD ignition, Flowmaster exhaust and that is about it. I live in a fairy new part of Dubai. And by my house there are a lot of blank roads. Often when I have nothing better to do I will just take my Camaro out there and have some fun. About two weeks ago I really wanted to see what the car was made of. I flored it. I soon hit 180kph. And it had stopped there and I just continued going 180. Is that right? You would think I could go faste that that right? Do you guys think something is wrong or there is a governer or something. I mean 180 is not that fast.
Old Jul 10, 2009 | 12:26 PM
bezerker's Avatar
Unsure what that equates to in MPH, but I believe the 91's had a limiter built in.
Old Jul 10, 2009 | 03:26 PM
180 kph = 111.8 mph. The Camaro is speed limited to 110 mph, so you're right there. You can override the system: http://www.thirdgen.org/unlimited but be aware that part of the reason yours is limited is because of the speed rating of the tires that the car came equipped with. You go pushing the speed way past the tire rating, and you're just pressing your luck. If you've already upgraded to higher speed rated tires, then that part isn't an issue any more.
Old Jul 10, 2009 | 11:45 PM
Thank you for your help. I was thinking about running Nitto tires. Would that be okay to go super fast in. I am sure my tires would explode if I went over 110 in the ones I have on now. But would Nitto Invo's work okay?
Old Jul 11, 2009 | 12:50 AM
Nitto Invo's are Z rated tires. Good for mph of 149 and up (I'll let you do the conversion).
I think you're going to need to be going downhill with a good tail-wind to get your 305 powered car going that fast.
Old Jul 11, 2009 | 05:25 PM
Thanks man but it is a 350 car
Old Jul 11, 2009 | 05:29 PM
Saint_Ali's Avatar
same difference
Old Aug 18, 2009 | 11:48 PM
Ether's Avatar
mine is a 305 car and it downshifts into passing gear at 115. maybe it already has been bypassed in mine.
nxtlevl
Sep 22, 2013 06:59 PM
RonnieJ86
Dec 5, 2012 08:58 AM
z28?SS?
Jan 20, 2011 01:51 AM
