Can anybody tell my rpm
Old Jan 4, 2010 | 06:51 PM
Cblaze's Avatar
Default Can anybody tell my rpm
im putting small block in my car and the six cyl trans got low gears. need to know what my rpm be at 65 if i just change the bellhousing on my trans and use it.the differential has 3.42 gears and 255 60 15 tires and trans has .76 overdrive gear
Old Jan 4, 2010 | 06:53 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
I dont think thats such a good idea
Old Jan 4, 2010 | 07:00 PM
Cblaze's Avatar
Im only putting a 260 horse motor in it .i know the trans wont take to much i would like to put over 300 horses in it but i cant afford a t56 or tko 500
Old Jan 4, 2010 | 07:33 PM
If you are keeping the same transmission and rear the RPM will remain the same.
Old Jan 4, 2010 | 07:36 PM
microkid's Avatar
March 2011 ROTM
Technical User
it will be roughly 2100 rpm at 65 mph. i dont see why its a bad idea though
Old Jan 4, 2010 | 07:42 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
a non world class T5 is already a weak transmission to begin with, and putting a V8 in front of one set up for a v6 .....
and isnt the input shaft a different size as well?
Old Jan 4, 2010 | 11:27 PM
Cblaze's Avatar
everybody on here told me the t5 in it right now would hold the power. i asked summit about the input shaft and they say it would work if i changed the bell housing and slave cyl. i could buy a v8 one from a auto salvage but . six cyl one got lower gears . doesnt matter if it wont hold up.any one on here using 6 cyl t5 on v8? also my tach is off but i am not worrying bout it since its gets changed when the motor does
Old Jan 5, 2010 | 04:53 PM
Cblaze's Avatar
Also im gonna rebuild it and throw a short throw shifter on it so that should help it.im just about reworking the whole car
Old Jan 5, 2010 | 05:13 PM
mighty mike's Avatar
i did the same exact thing u did, same gears, v6 tranny, and i did it with a GM performance motor. it holds good. yes ur tac will be off but just get one form autometer. and youll be faster than a iroc because u do have lower gears. trust me i know form first hand experince.
