92 RS 305 v8
Old Sep 12, 2009 | 12:43 PM
Purple92RS's Avatar
Angry 92 RS 305 v8
i love this car but i hate it cuz i cant figure out what the problem is, was hoping someone could point me in the right direction.
just got it outta the shop after 10 weeks of dude trying to figure it out
ive replaced iac, tps, map, maf, engie temp sensors, now it wont stay running unless its in nuetral,
new distributor, cap button plugs wires,
replaced numerous vacume hoses,
if i try to start it it runs for about 30 seconds tehn stalls out
and just found yesterday that if i put it in nuetral it runs and idles fine
just got all new seals on valve covers intake manifold,
new fuel pump/filter,
new ecm
ignition coil
checked fuel injectors they seem to be fine
any help or ideas would be greatly appreciated i swear ive checked everythin hopeing its just something simple im looking over but im not sure thats why im here asking
Thanks,
Justin
Old Sep 12, 2009 | 05:00 PM
Maladjusted throttle valve, and the IAC does not have enough range to compensate ?? Also make sure the EGR is closed at idle speed.
Old Sep 12, 2009 | 05:26 PM
if u have adjustable idle screw on the tb try adjusting it as though u were setting the idle higher.
Old Sep 16, 2009 | 01:03 PM
Craigbr15's Avatar
Also, its a long shot but maybe your cat is clogged? Does the car misfire at all? Any problems shifting gears? I have the exact same camaro, never had these symptoms.
