92 RS 305 to 350 Conversion?
Old Dec 24, 2007 | 01:46 PM
SWGRezec's Avatar
Default 92 RS 305 to 350 Conversion?
What all will I need to get my 1992 RS 305 TBI converted to a 350?
Old Dec 24, 2007 | 03:46 PM
MadMikeZ28's Avatar
Default RE: 92 RS 305 to 350 Conversion?
A 350 engine.
Then to do it up right...350 injectors, computer and prom, knock sensor and ESC. But the 350 will still run using those parts from the 305
Old Jan 18, 2008 | 03:59 PM
newtocamaros's Avatar
If you remove the 350 your self umbillical cord it (leav all wirirng that goes to engine) that is how i did my 350 swap made it alot easier if you need to switch out connecters for anything. I used the 305 comp and only had to change one of them for the throttle body
Old Jan 18, 2008 | 04:06 PM
rawdex's Avatar
I've got a n rs to z28 car with a 383 stroker and a custom accel dfi. what nigtmare. I'd take newtocamaros advice unless your willing to spend a lot of money.
[IMG]local://upfiles/11417/2E71772CC00E4E4490878EAC7BED37A5.jpg[/IMG]
Old Jan 20, 2008 | 10:58 PM
christian's Avatar
if you make it a carb, all you have to do is add a fuel pressure regulator, and the motor mounts will be the same also
NEVERLETITDIE
Mar 8, 2010 11:06 PM
RubberDucky
May 8, 2009 04:42 PM
stangslayer
Dec 19, 2007 02:31 PM
davefh
Aug 6, 2007 08:40 PM
davefh
Apr 3, 2007 10:05 PM
