88 iroc z engine suggestions?
my car is an 88, but the engine is out of a 91, i believe it had the 305 tpi, but now is the 350 tpi, it runs great and all, but i want more, my question is, will a 400 from a 70ish caprice be a good build? will the tpi intake bolt up to the 400 small block? can i tune the computer to feed more fuel that will be needed? thanks in advance
I don't know for a fact about either the intake, or the T5, someone else will know for sure, but I'm not sure how you are going to get around the knock sensor required for the computer controller distributor......
anything more than a mild 350 and it will start separating, even with careful shifting and no burnouts. but if you happen upon a spare or want a reason to buy a better trans, go for it
Withered962
07-26-2006 10:26 AM
