86 305 code 33
Old Sep 12, 2010 | 06:58 PM
warbeckn's Avatar
Default 86 305 code 33
I am new hear and tried to find the answere to my question.
I have an 86 iroc, bought it in 88. Started to have maf codes and took it to a dealer. Under warrenty they replaced the maf computer and chip.
Worked for awhile and then I parked it due to starting a family.
I got it out off and on and still had problem with the code 33.
Last year I decided to work on it. I replaced the maf senser which I didnt think it needed. I took it to a dealer and it sat there for 2 months. That was enough of that. I have found the bulitin that there was a problem with the original chips. I replaced it. Still have the code. Now I am looking the the power relay and the burn off relay. I also found the bulitin that the part numbers were wrong in the GM books. Where are the relays. I found one by the battery where is the other one.
I am sorry if this problem has been addressed before and I didnt find it.
Any help would be great.
Old Sep 12, 2010 | 07:16 PM
warbeckn's Avatar
I also wanted to add that when it is cold it runs great. I can burn the tires all day long.
When it heats up is when it acts up. This is why I was thinking it is a relay breaking down.
Old Sep 12, 2010 | 08:00 PM
microkid's Avatar
March 2011 ROTM
Technical User
here is a photo for the relay locations. i would look into them and the wiring if everything else has been replaced and its still creating issues https://camaroforums.com/forum/attac...9&d=1280189017
Old Sep 13, 2010 | 09:54 AM
warbeckn's Avatar
Thank you so much!!!
What relay is right in front of the battery?
This is a great site. There is alot of information here.
Old Sep 14, 2010 | 08:08 PM
microkid's Avatar
March 2011 ROTM
Technical User
that one im still trying to figure out. mine was replaced and rewired and some point, and i would like to know where it goes to as well
Old Sep 24, 2010 | 08:51 AM
warbeckn's Avatar
After 22 years I finally got it!!!
I bought a chiltons book and just started to check everything.
The first thing I checked was the throttle position senser. It was suposed to be between .45 and .6 volts when the key was on and not running.
It was at .65, set it at .53 and runs great!!! I also found the cut off relay was mounted on a rubber strap. I think way back then the dealer thought it was vibrating.
The relay in front of the battery is the cooling fan relay.
Old Sep 24, 2010 | 07:57 PM
microkid's Avatar
March 2011 ROTM
Technical User
ah, well thanks. now that i know what that is i can remove it im glad you got it running well
kalim03
82-92 V6 Tech
Feb 7, 2010 11:56 PM
tycomps
Feb 16, 2008 09:56 PM
crusherdrivinfool
82-92 V6 Tech
Dec 16, 2007 11:12 AM
350rs
May 16, 2007 09:02 PM
dblock1989
Mar 6, 2007 08:54 AM
