4th gen wheels on a 3rd gen
Old Jan 29, 2008 | 12:31 AM
iroc334's Avatar
Default 4th gen wheels on a 3rd gen
ok just as the topic says i got a real good deal on a set of 4th gen wheels i wanted to know if a 86 wheel will fit on my 86 iroc???
Old Jan 29, 2008 | 12:55 PM
Default RE: 4th gen wheels on a 3rd gen
ORIGINAL: iroc334
I assume you meant 96 wheels?
Backspacing on third gen wheels are in the 5.25" range and backspacing on fourth gen wheels is 7". Both wheels are 8" wide. I have some 4th gen wheels and have tried fitting them on my 91. Wheel spacer adapters will be needed to make it work. At least 1" thick should do it, otherwise they won't clear behind the wheels/tires.
Old Feb 2, 2008 | 02:50 PM
iroc334's Avatar
about an inch spacer huh???? ok thank you
Old Feb 7, 2008 | 07:10 PM
iroc334's Avatar
will the front and back be he same backspacing? i have had the car in storage for about two years and im not as ontop as i used to be with facts and info..... i do remember the front and rear are stamped on the 86 is that for different backspacing
78maro
Mar 31, 2011 08:59 AM
buckfever
Feb 7, 2008 06:15 PM
Camaro Man 1999
Jan 21, 2008 04:27 PM
remoulds
Dec 30, 2007 12:41 AM
HEAVYCHEVYMAYNE.
Nov 22, 2007 07:05 PM
