350 heads on a 305 ci
Old May 28, 2010 | 12:07 PM
Badrs2810's Avatar
I haven't looked up the numbers yet I'm out to lunch my car is at work when I get back to my car I will. Where are these numbers located and how will I know if they are ho numbers?
Old May 28, 2010 | 12:09 PM
The casting numbers are on top of the heads, under the valve covers.
Then you can look them up here: http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
and here: http://www.mortec.com/castnum.htm
Here's something to read about the 305 heads, cam, etc.: 305 Head Tech
Old May 28, 2010 | 12:12 PM
Badrs2810's Avatar
I'm located in nc and I think fuel injection but is carb better in your mind? Probably easier for carb but tbi kind of sucks. If i had tpi I'd stay fuel injection I'm up for ideas though
Old May 28, 2010 | 12:14 PM
heres some stuff from the thread that nobody read.
u want castings that end with either 081 or 416.
305 heads are all cast iron and have combustion chambers around 58cc with valves that are as small as 1.74/1.50 (early heads) and as big as 1.84/1.50 (later heads). They could be had in either the early style 86-down bolt pattern or the later style 87-up bot pattern depending on year and application. If they use centerbolt valve covers then they have the 87-up style intake bolt pattern. They can be modified to take a larger 1.94 intake valve but the ports are still slightly smaller than any 350 head, at least on the intake side, and the valve centerlines are slightly closer together to fit down the bore of the smaller 305 engine (which is wy 1.94/1.50 is about as big as you can go with them).
Old May 28, 2010 | 12:17 PM
I read it, and answered your queries. Are you including yourself since you said "nobody"?
Old May 28, 2010 | 12:18 PM
yep. lol. feeling spunky today.
Old May 28, 2010 | 12:20 PM
I'm spunky every day!!! What was this thread about again...oh yeah!! lol
Old May 28, 2010 | 01:23 PM
Jr. Mechanic's Avatar
August 2009 ROTM
I say skip the 305 HO heads and go right to Vortecs.
Old May 28, 2010 | 01:44 PM
You are referring to the 350 and not 305 Vortecs?
And don't forget then, that a new Vortec style intake manifold will need to be purchased too.
So, how much of his money have we spent so far?
Old May 28, 2010 | 01:57 PM
  #20
August 2009 ROTM
The 305 Vortecs can be had pretty cheap, and might be a good choice for him.
If you can get a good enough deal on a set of Vortecs, the $160 for an intake is well worth it IMHO, unless you're running a huge cam where you might run into problems (ask me how I know ) but this is the case with pretty much all stock heads.
Luckily I think I have my valve train geometry figured out pretty well, it wasn't as bad as some people make it out to be.
