350 engine swap (i'm prepared to be hit for dumb questions)
Old Jan 14, 2008 | 11:27 PM
White Comet's Avatar
Default 350 engine swap (i'm prepared to be hit for dumb questions)
hi, im new to the camaroforums and had some questions while helping my brother, hes not much of a forum guy so i signed up to try to seek out help. he has a 91 camaro RS and is in the process of swapping in a carbed 350 form 73. from his searching he hasnt found anyone that has managed to do this yet. is there anyone on here that sucessfully did this? and is there any advice? I'm alwso wondering if anyone can post pics of the underside of a 3rd gen camaro with dual exhaust pipes, we are trying to determine the best way to run dual pipes for the v8 but the car had a single pipe from the factory and was v6. thank you for any help
Old Jan 15, 2008 | 11:39 AM
camaro1984's Avatar
Default RE: 350 engine swap (i'm prepared to be hit for dumb questions)
look at the faq and you will see everything you need to do in order to swap from v-6 to v-8 and the dual exhaust thing is kind of hard to do on these cars but id focus on getting the car running first
Old Jan 15, 2008 | 11:47 PM
^ i didnt see anything mentioned about gonig to a 1st gen 350 in the faqs
Old Jan 16, 2008 | 12:31 PM
camaro1984's Avatar
all chevy v-8s are the same basic design the motor mounts are all the same along with bellhousing bolts everything from a 4.3 to a big block are the same
Old Jan 16, 2008 | 02:56 PM
Jr. Mechanic's Avatar
August 2009 ROTM
https://camaroforums.com/m_4042/tm.htm
Old Jan 17, 2008 | 07:21 AM
^ i checked out the faqs, on some other forum someone said that no one ever swapped a 1st gen 350 into a 3rd gen camaro. i know everything will bolt up nicley as far as motor mounts, ps and other things, but i was told that everything woudl have to be rewired. i dont believe that for a second though
Old Jan 17, 2008 | 07:26 AM
Coveted Hilton's Avatar
im doing exactly this right now, i have an 82 camaro.
it was originally a 4 cyl car, then someone along the lines converted it to manual and put an 8 cyl in it (im guessing tpi)
im in the process of puttin an all out engine im building into it with a powerglide.. its a 1973 camaro engine..
honestly tho, i plan to pretty much eliminate the whole harness except for the lights, signals, gauges and wipers.
other then that, there will be nothing for harness left.
Old Jan 17, 2008 | 12:02 PM
camaro1984's Avatar
you wont have to rewire youll just have to remember what all the gage wires went to and hook them up to the new engine
Old Jan 17, 2008 | 10:31 PM
August 2009 ROTM
ORIGINAL: White Comet
All pre 87 350's ARE THE SAME! Then the only differences from 87 and up were center bolt valve covers, and one piece rear main seal, then as you get into the newer crap, that is completely different. Everything you need to know is in that FAQ.
Old Jan 17, 2008 | 11:04 PM
camaro1984's Avatar
thank you for understanding what i was trying to say
