305 Tpi, not running to its full
Old Sep 15, 2010 | 01:48 PM
jamguitarist91's Avatar
Default 305 Tpi, not running to its full
I have a 505 TPI in an 88 Iroc, the car likes to chug, run at half power, randomly die, and overheat easily.
Things I'm doing are:
New heated 02 sensor for the longtube headers
Full tune up
Also my car is a 1988, but for some reason it has a MASS air flow sensor AND a MAP sensor installed?? Yea...
Old Sep 16, 2010 | 07:52 PM
microkid's Avatar
March 2011 ROTM
Technical User
sounds like theres a lot possibly wrong. we need more details. does it smoke, use oil, use coolant? what else is done to it. according to your other thread you wrecked it
Old Sep 21, 2010 | 07:47 PM
It burns no oil, it ran like this before the wreck, it doesn't tick, it runs great till it warms up usually. does not use coolant.
Old Sep 21, 2010 | 07:51 PM
microkid's Avatar
March 2011 ROTM
Technical User
i would start with the timing and go from there. there could be some sensor issues, a broken or inop coolant temp sensor could cause a few issues by telling the ecm the engine temp is -40. does it run rich, normal, or lean? there could be other issues as well, but lets start off with the simple
Old Sep 21, 2010 | 10:33 PM
silversrt400hp's Avatar
a 505 hugh? thats a big tpi
Old Sep 24, 2010 | 08:54 AM
warbeckn's Avatar
Check the throttle position senser. I had mass airflow problems for a long time.
My senser was set open too far. I have an 86 but I think 88 has the same tpi.
Old Sep 27, 2010 | 06:20 PM
black89rs's Avatar
are maf sensors supposed to glow??
Old Sep 27, 2010 | 07:39 PM
microkid's Avatar
March 2011 ROTM
Technical User
during the clean off cycle after shutting off the key, that is normal. during operation, im not sure
TXMEL13
Jun 8, 2011 12:01 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
bdunegan
May 3, 2008 09:08 AM
SickSickSick
General Racing/Tech
15
Jul 7, 2006 10:56 PM
