305 TBI difficulty with cold start
I've been having trouble with my 92 TBI starting cold. It will start with the familiar rev, but when it goes down, it shuts off. To re start, I have to hold down the peddle to the floor, then it will start as if it's a flooded carb. Runs rough blowing fuel out the back, then it clears up and runs fine. I was thinking it might have a bad coil, but not sure. No check engine light either. Any input would be appreciated.
Could be a bad coolant temperature sensor, not the one for the gauge. It's located near the thermostat housing, and if unplugging it makes the cold engine run better, replace it. This one won't necessarily throw an error code if it's bad. By the way, did you check for codes?
(Post 732504)
The starting issue is gone, it starts fine, and doesn't stall out. The other issue of sitting after warmed up, and running rough is still there. I'm gonna hijack my own thread and ask what could cause the second issue.
I had a slightly different problem: Car would crank for like 30 seconds before starting in cold weather. Started immediately in warm weather. Problem turned out to be a oil pressure sensor/switch (located on the drivers side firewall). I got the replacement from Hawks:
https://www.hawksmotorsports.com/oil...89-92-tpi-tbi/ |
Originally Posted by Stevolwevol
(Post 732512)
https://cimg8.ibsrv.net/gimg/camarof...4f72203345.jpg The new ones (from Jegs) https://cimg6.ibsrv.net/gimg/camarof...eca9a2ad2c.jpg |
