305 to 350 swap>?
Old Jul 29, 2007 | 06:54 PM
Pro_built7's Avatar
Default 305 to 350 swap>?
will any old style 350 bolt right into the stock 89' 305 RS engine mounts ? i want to pick up just a regular 350 block and build it, but idk if it would fit ? thanks !
Old Jul 29, 2007 | 08:06 PM
1983camaro's Avatar
Default RE: 305 to 350 swap>?
i would get 350 camaro mounts just to be safe, usually when you swap a motor , in my opinion you should get new motor mounts.
Old Jul 30, 2007 | 01:19 AM
Pro_built7's Avatar
ya i was planning on it, but will an old 350 block bolt right in without any mount mods ?
Old Jul 30, 2007 | 03:23 AM
1983camaro's Avatar
yeah, 305 and 350 is the same block.
Old Jul 30, 2007 | 04:48 PM
parker987654321's Avatar
any 350 will fit but it is not the same block it is 45 cid bigger which is not much but it is different. I just put one in my z28.
Old Jul 30, 2007 | 05:08 PM
blackz87's Avatar
305/350 have the same external dimensions and are interchangeable in the engine bay. It is the internal dimensions that make the big difference. That is why so many people try to pass off a 305 as a 350.[sm=gears.gif]
Old Jul 31, 2007 | 11:23 AM
Pro_built7's Avatar
alright thanks guys,
i'm pretty sure a 305 cannot be made into a 350 or 383 can it?
Old Jul 31, 2007 | 11:31 AM
blackz87's Avatar
ORIGINAL: Pro_built7
No, it cannot.
Old Jul 31, 2007 | 01:52 PM
1985RS's Avatar
i'm pretty sure a 305 can be turned into a 350. its the same block, just different crank rods pistons and cylinder bore.
Old Jul 31, 2007 | 02:08 PM
blackz87's Avatar
ORIGINAL: 1985RS
Your pretty sure, Ok try it and you will not have wall thickness left between cylinder bores. Internals of the castings are different between the 305/350 blocks. Pretty sure dosent cut it.
