2 questions...
Old Jun 3, 2011 | 06:10 AM
A1bertmarkovski's Avatar
Default 2 questions...
1st is what size tires are good on an 88 iroc-z camaro...im used to suvs so im not sure what sizes to get...now i ha e 235/60/15 but can i go smaller or bigger(only because its hard to find cheap tires for those)?
2nd what could cause my intake to suck to much air? It basically sucks too much air and causes a choke...if i put my hand over it it will idle fine then i take it off and it starts to choke...
Thanks!
Old Jun 3, 2011 | 06:59 AM
blackz87's Avatar
What Camaro model, wheel size and engine do you have?????
Old Jun 3, 2011 | 08:54 AM
Thanks!
Your Idle Air Control (IAC) valve may be stuck open.
Old Jun 3, 2011 | 10:01 AM
I have an 88 iroc-z28 5 speed with a 305 with 15inch wheels
And the iac valve...is that go with the mas?
Old Jun 3, 2011 | 02:01 PM
One more thought though first. If the IAC isn't closing when it should, you'll have a high idle. You didn't mention anything about your idle speed, how is it?
Old Jun 3, 2011 | 05:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
check the iac, and check the bushings on the throttle blades, they wear out and can cause it to stick open
Old Jul 1, 2011 | 08:55 PM
Stevolwevol's Avatar
Thanks!
In 88 IROC's came standard with 15" wheels. 16" wheels cost extra. If they are 15's then the 235/60 would be stock replacement. If 16's then 235/50. I just bought tires for my rs, but I went to 245/50 cause they were less than 235's. It's only 10 mm difference, but I like them a little wider anyway. The tires I mounded were Rikon Raptor ZR. I have no complaints so far. The reviews for this tire were good, so I got em. I spent a bit over $400.
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
