2 headlight questions...
Old Dec 18, 2007 | 07:47 PM
305GIRLIE's Avatar
Default 2 headlight questions...
OK the headlight dosn't work just stopped one day (both of them), so a friend pulled out the headlight switch, while I got a replacement from the dealer. Well when I replaced it they still don't work, and not only that but I cant seem to find where it was originally ancored and neither does he (and it just has to be ancored somewhere, it doesn't work if it's just flopping around.. I tried any clues guys??? and one more question if its not the headlight switch, ora fuse, anything else it might be. Thanks guys this will be the last thing I need to get my babe on the road!!!
Old Dec 19, 2007 | 02:07 AM
MadMikeZ28's Avatar
Default RE: 2 headlight questions...
There would be a fuseable link on one of the starter wires. One of them is power to the headlights. Check them close. Sometimes the wire does not melt away and they look good but they will corode and melt inside the connector.
And the headlight switch will anchor with a nut to the bezel. The nut is more like a bolt with a hole in it and it threads into the metal braket on the switch and the rod on the **** goes through the hole.
Old Feb 12, 2009 | 10:36 PM
9camaro1's Avatar
i found those fusable links but neither were bad. Im having the same problem.
Old Mar 3, 2009 | 11:15 AM
1989_RALLYSPORT's Avatar
check the grounds for the headlights. if i remember correctly they bolt to the core right between the lights in the engine bay under a lip mine was bad and one side didnt work
Old Mar 3, 2009 | 11:28 AM
blackz87's Avatar
Yes, burnt out headlights.
Old Mar 15, 2009 | 11:40 PM
ramair_bryan's Avatar
Default my head lights as well.
Hi guys.......me too. except they come back a few days later. Kind of like inlaws. Ground wire was good to know it's location. I'll check it first. Then I'll jack it up and check those fuseable links at the starter. Thanks again, I'll let you know what it is........more later........bryan.
Dana
Jan 28, 2012 12:57 AM
hotrodz28454
Mar 23, 2010 03:13 AM
camaro97x1
Apr 20, 2008 11:13 AM
blink18236dude
Jul 10, 2007 10:53 AM
81CanuckZ
Sep 10, 2006 11:04 PM
