1986 Camaro knocking from bottom of engine
Old Aug 8, 2011 | 08:04 PM
  #31
Stevolwevol's Avatar
Well, do a valve job and you have a rebuild. A rebuilt 305!
Old Aug 8, 2011 | 08:12 PM
  #32
mgg4591's Avatar
Lol the valves are already done. I pulled the heads to do the seals and clean out all the sludge that was plugged the oil galleries. I have a bunch of pics of the mess that was in there. Anyway, i did the seals and the valves. All that's left is the bottom end. It was all ready for the road until the bearing went. Wasn't smoking out the tail pipe at all.
Old Aug 8, 2011 | 08:15 PM
  #33
mgg4591's Avatar
Old Aug 8, 2011 | 08:16 PM
  #34
What cam is in it? I don't remember which engine you have.
Old Aug 8, 2011 | 08:39 PM
  #35
mgg4591's Avatar
Its a stock 305 4 barrel
Old Aug 8, 2011 | 08:49 PM
  #36
microkid's Avatar
March 2011 ROTM
Technical User
it looks a lot better than my 305 did
Old Aug 8, 2011 | 10:24 PM
  #37
Hmmmmmmm....the plot thickens! How did you "clean out all the sludge"? Perhaps your clean out caused some crud to form a blockage in the bearing oiling hole, resulting in the spin.
Old Aug 9, 2011 | 01:25 PM
  #38
mgg4591's Avatar
Well i removed the heads and soaked them in purple power until all the grease was off of them. As for around the rockers i just sucked it up with a wet vac.
Old Aug 9, 2011 | 02:36 PM
  #39
djs383's Avatar
If you've already described what you did in another thread, I didn't see it but I have a few questions.
1. When you removed the heads, did you completely tear them down before cleaning?
2. Did you use new head gaskets, intake gaskets, new head bolts?
3. Do you think you could have knocked off some carbon desposits into the bore?
I only ask because I have seen more than once a good idea (cleaning up the heads) turn into a bad decision if just a little of that rock hard carbon gets into the bottom end. It tears up lead bearings in just a few moments. I have found that I am unable to clean heads without some type of media blasting. Even on my race bikes, I never cleaned a head unless it was completely disassembled, even then I had more than one issue (with 4 strokes, never a 2 stroke)
Old Aug 9, 2011 | 02:46 PM
  #40
The fact the engine now needs repair is probably just as well I guess.
The above pictures can be described by one word....well two; "yuck" is the obvious one, but "abuse" is what put those crunchies there.
