won't stay running
I just bought my son an 86' camaro with a 2.8L. The car starts runs and drives great but once it gets warm it die's. after 10 or 15 minutes it will start again and die, it's driving me crazy. plzzz help
If the lamp is lit, there has to be a code. From your problem description, it appears that the engine has problems when the ECM goes into the closed loop mode. This most likely is the result of a sensor problem, but you need the trouble code to find the one that is causing trouble.
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
