Wont stay running 3.1L
Old Jun 6, 2009 | 08:33 AM
[god]speed's Avatar
Default Wont stay running 3.1L
I had to bypass the ignition and put a push button start on my 91 rs
It has been setting for three moneths during winter in ohio I get it to start up but have to constantly rev it to prevent it from dying. Can anyone offer any suggestions?
Email me at deaddopestar@hotmail.com please
Aaron
Old Jun 6, 2009 | 08:49 AM
sounds like the throttle postition sensor, maf/map. could be a few other things. have u checked for trouble codes?
Old Jun 6, 2009 | 11:48 AM
1990CamaroRS's Avatar
Fancy Sparkle
are you getting constant fuel pressure??? when was the last time the fuel filter was changed???
Old Jun 7, 2009 | 04:41 AM
[god]speed's Avatar
I have not checked any codes, Im uncertain if i am getting constant pressure.
I replaced the fuel pump, filter, and lines December 2007 i believe
also replaced the uhm.... it might be Throttle Position Sensor. It connects into the intake pleneum after the throttle body.
It has sat outside with about a 1/4 of a tank of gas in it since the middle of winter in ohio, so that may have something to do with it as well i figure
The Car ran great great gas mileage plenty of power, it only has 109k on it. Then something caused my ignition to just completely go out, so this past week i wired a push start button to it. Might just need to drain the tank, replace the fuel filter then Seafoam the f uck out of it
Old Jun 7, 2009 | 11:29 AM
Fancy Sparkle
is the security light staying on for more than two seconds when you turn the key to on???
Old Jun 8, 2009 | 01:45 AM
[god]speed's Avatar
when I turn the key on the security light stays constant....
It was involved in a small collision airbags deployed my father bypass the airbag and it ran fine for several months.
Old Jun 8, 2009 | 04:03 PM
Fancy Sparkle
VATS, it's more than likely trying to cut fuel pressure. sometimes it will malfunction and not completely cut off fuel. that's where i'd look first.
Old Jun 9, 2009 | 09:45 AM
[god]speed's Avatar
Could you explain where the vats is and the procedure to fixing it?
Old Jun 11, 2009 | 02:17 AM
Fancy Sparkle
VATS= Vehicle Anti-Theft System. it's in the ecu. you can replace the ecu, but then you have to get a new key for the ignition. each key has a resistor "chip" in it, when the key is inserted into the ignition, that chip completes the VATS circuit. if the ecu doesn't see the correct resistance across, it will cut fuel or cranking power.
it's actually under the passenger side dash, and it's kind of a pain to get too. it should just be a matter of pulling the old ecu and installing the new one and getting the new key.
i still haven't gotten mine to work, so i'm just pulling the whole engine out and stuffing my sbc in there.
Old Jun 11, 2009 | 08:05 AM
Don't forget that there is a VATS module between the ignition switch and the ECU, The VATS module reads the key pellet resistance and sends signal to the ECM to allow thr injectors to work.
