Whoever is good with their ears
Old May 19, 2011 | 05:48 PM
RedCamFlash's Avatar
Default Whoever is good with their ears
Ok so i took a video with sound of a noise that my car makes. Let me know if anyone can identify the problem.
YouTube - ‪Some kind of noise‬‏
I swear it's not a prank or anything.
In case you don't see it in the more info it's a 1989 Camaro RS with a V6.
Old May 21, 2011 | 09:55 PM
Sheriff420's Avatar
Busted/bent pushrod? Loose/broken lifter?
It doesn't sound good.
Poke around with a mechanics stethoscope to see if you can pinpoint the sound.
You can get a mechanics stethoscope at Harbor Freight or Amazon.com for less than $5.
If you don't want to wait then push a piece of metal like a prybar or piece of brake like or something to your ear and poke around with it. If you do that you should push the flap of skin in front of your ear hole over it to plug that ear with the metal, then plug the other ear with your finger while you're poking around.
Old Jul 9, 2011 | 08:06 AM
jrc35jrc35's Avatar
I have this exact problem and came on here looking for an answer. My mechanic says it's just something going through the catalytic converter and it will stop on it's own, but I'm not so sure. It only does it while idling. Did you happen to find the problem?
Old Jul 9, 2011 | 12:10 PM
With the lousy sound system on my laptop, that noise could be just about anything. Follow Sherrif's advice and try to locate where the sound is coming from.
1989fbody
Aug 12, 2009 07:32 PM
ihavenotitle
Jun 1, 2009 08:18 PM
trexbarney7791
May 22, 2008 09:11 PM
BeachBrad
Aug 10, 2007 11:54 AM
