Speedometer Issues
Old Mar 16, 2008 | 03:52 PM
bconz350's Avatar
Default Speedometer Issues
Ok I bought a camaro and it has its problems. First I can't hook up the speedometer. This may sound like a dumb question but is the speedometer on a 92 RS electronic? It has an aftermarket borg warner t5 in it which has a mechanical sender. Also I need to hook up the back up lights. They don't come on when I put it in reverse. PLEASE HELP!
Old Mar 18, 2008 | 02:23 AM
sewerrat's Avatar
Default RE: Speedometer Issues
I'm quite sure yours is mechanical drive speedo. Check for a broken inner cable or if it unhooked on the dash side.
For the rev lights check your rev. s/w located about midway of your trans on the drivers side. Disconnect the electrical connectorand jump the two terminals together on the connector with the key in the on position to see if your back lamps come on. Good luck!
Old Mar 18, 2008 | 10:03 AM
bconz350's Avatar
Thanks, Actually I found out that the 90-92 speedometers are in face electronic. Which brings me to my next question: Can I change the sender on my transmission to be electronic?
Ted Von Kampen
Nov 10, 2014 09:18 PM
abritto3
Sep 26, 2008 09:59 PM
dbx
Jun 16, 2007 11:39 PM
pistolpete_67
Feb 23, 2007 11:52 PM
74Z28
Feb 17, 2007 01:19 AM
