rockstarbass1 |
10-12-2009 10:27 PM |
something burning?
ok well i have a few other posts on here but long story short i just bought a 92 rs. i was told it had a rod knock. the cars been sitting for a year or more. battery shot tires flat and broke the seal. so on and so forth. so i get the tires fixed. added a **** load of fuel injector cleaner stuff in the has tank to help do somethin with the bad gas thats been in there for who knows how long and add a few gallons of gas. jump the car and she starts (the battery sat on an industrial charger for hours and was only giving 18 cranking amps) so i got it to run!!!!!!!!! i drive it home with it running like crap and notice if i let off the gas it idels rough. get home and its smokeing some where. pretty good too. today i get a new battery for it throw it in and she fires right up! i let her idel for a good 5min while going over the car some more and it ran good. sounded good and no knock! there is a little bit of noise comming from one of the pullys but what do you expect from a car sitting so long. but shes still smokeing. i noticed theres alot of oil on the valve covers. so i dont know if its just the oil all over bunring up. or if it has a head gasket leak, i did notice the old owner has a bottle of antifreeze in the back seat wich isnt a good sign but also noticed that the coolant resivor is filled up past the hot fill line when the motor is cold. the car has 125k on it, so if this thing isnt knokcing i dont need to jump on my motor swap right away! what do you think i should do or start? "gunk" or clean the engine bay and take a hose to it sounds good to me. clean stuff up so i can see whats leaking better. also its been dark out every time iv started the car. oil change obviously. i as told i should put some "zmax" in it also? or maybe some lucus oil with it? thanks chris
