My 3.1 V6 rebuild and build thread
Old 03-11-2009, 05:28 PM
Intrepid781's Avatar
Ok, well I wasn't sure cause we always do that swap with S-10's and we have to change the intake and use a throttle body so I wasn't aware of the different fuel rails. Good to know though in case I ever pick up another 2.8 or 3.1L camaro.
  #32
Old 03-12-2009, 06:17 PM
[god]speed's Avatar
Originally Posted by 1990CamaroRS
yes, it is a direct swap. i think running 3.4 injectors on a 2.8 would cause it to run just a little rich though.
The 3.4L uses 17 lb injectors whereas the 2.8 uses 15lb or maybe 13lb ( i think) and it would cause it to run rich, Possibly dropping a Code 45, however I believe that an Adjustable Fuel Pressure Regulator from the 305's fits 60* V6's so you could dial it in
Could you keep posting more pics?
  #33
Old 03-13-2009, 08:53 AM
I just bored out the intake to make it match a 4.3L's intake bore but that was with TBI, a regulator would be a much easier option.
  #34
Old 03-29-2009, 03:22 PM
wazgold's Avatar
Cool just a question?
found a weird little jot from a gm tech site about a 3.8 liter ho? turbo charged making 360 hp @ 5200 rpm in a 89 trans am, web site www.gtasourcepage.com/89pmdplaythings some test bed vehicle with copper racing gaskets and 22 pounds of boost had a six speed from a vett too.....hope this helps lots of luck
  #35
Old 04-02-2009, 02:52 PM
1990CamaroRS's Avatar
Fancy Sparkle
ya, i've been a little busy lately with work. haven't had a lot of time to get to the car
ah yes, the old GTT Trans Ams. think Buick GNX engine in a 3rd gen Trans Am. they were discontinued because they regularly were beating up Corvette's, and GM didn't really like that too much
  #36
Old 02-19-2010, 01:17 AM
Fancy Sparkle
this is back on ladies. looks like i'm gonna do a hybrid, 3400 heads and intake on a 3.1
lownoma
04-28-2023 07:36 AM
DarlingReject
03-26-2013 06:23 PM
rydeer
08-01-2012 06:41 PM
Dadz67
03-22-2012 02:45 PM
redhoss02
82-92 V8 Tech
11-21-2009 09:07 AM
Quick Reply: My 3.1 V6 rebuild and build thread
