My 3.1 V6 rebuild and build thread
Old Mar 6, 2009 | 11:38 AM
  #21
1990CamaroRS's Avatar
Fancy Sparkle
the heads are the main limiting factor with the 3.1. they don't flow over 4500rpm.
Old Mar 7, 2009 | 08:22 PM
  #22
[god]speed's Avatar
Shouldn't the 95-08 3100 Aluminum Heads fit Perfectly?
Old Mar 8, 2009 | 11:04 PM
  #23
Fancy Sparkle
i'm not really sure. i'll have to check into that.
Old Mar 9, 2009 | 04:52 AM
  #24
[god]speed's Avatar
well I know there is a site building up a 2.8 with 3x00 parts online for a fiero so I assume the heads from a 3100 will fit the 3.1
Old Mar 9, 2009 | 12:05 PM
  #25
Fancy Sparkle
ya, it should work.
Old Mar 9, 2009 | 01:07 PM
  #26
[god]speed's Avatar
http://www.domesticcrew.com/660/hybrid.html
Perhaps this will help if you have not already read it?
Old Mar 10, 2009 | 08:33 AM
  #27
Intrepid781's Avatar
I've done a few 3.4L block swaps into 2.8L S-10's before but I've never messed with a Camaro. Is it basically the same thing just a direct swap for a 3.1 pretty much? Could you use the 3.4's injectors in place of the 2.8? I've always wondered.
Old Mar 10, 2009 | 12:06 PM
  #28
Fancy Sparkle
yes, it is a direct swap. i think running 3.4 injectors on a 2.8 would cause it to run just a little rich though.
Old Mar 11, 2009 | 06:34 AM
  #29
Well actually I meant swapping out the 2.8 for the 3.4 and using the 3.4's injectors but I didn't know if it could be done or not. I guess it can then?
Old Mar 11, 2009 | 01:25 PM
  #30
Fancy Sparkle
ya, it should be a direct swap. you'd have to use the 3.4 injectors on the 3.4, the fuel rails are designed for them. (3.4 uses different fuel rails than the 3.1/2.8)
