lets talk cold air
Old Jul 13, 2011 | 01:59 AM
garrison86's Avatar
Cool lets talk cold air
im considering putting a cold air intake on my 92 rs 3.1
any suggestions? pictures greatly appreciated.
Old Jul 15, 2011 | 11:55 AM
djs383's Avatar
I really don't think its worth it, you won't experience any more gains than a good tune up would give you.
Old Jul 15, 2011 | 06:12 PM
If you do want to put in a cold air intake, make sure it is getting air from outside the engine compartment, and use proper size plumbing. A lot of the cold air intakes touted on places like E-Bay tur out to be hot air intakes, which are worse than the stock set up.
Old Jul 16, 2011 | 02:19 PM
garrison86's Avatar
we had a similar discussion in the parking lot the other day we just finished a full tune up and started discussion putting in the K&N air filter or oping for a cold air intake. so far all signs are pointing to just going for a new K&N air filter
Old Jul 16, 2011 | 02:35 PM
inanitydefined's Avatar
If you care about your motor, please don't use an oil bath filter. They let so much more dirt in. We can tell most of the cars with k&n filters by the oil. Use a larger oem style paper instead.
If you don't mind building the system yourself, the best air box hands down to use for a smaller motor is the cylindrical box out of a ford pick up. You'll keep oem filtration, have a larger filter surface, and be able to flow more air than your motor can use, with a good air flow profile
Old Jul 17, 2011 | 07:25 PM
garrison86's Avatar
thanks for the impute , im also looking in to coating the intake valves to cut the temp?
my main goal is to get the most gas mileage out of my car and still have enough get up n go to deal with the stupid short on ramps after lights in my local area.
Old Jul 25, 2011 | 02:52 PM
cbr600rx7's Avatar
Stay away from the K&N filters. They do not filter nearly as good as the paper filters and the small 1-3 horses you may pick up are going to be at the expense of your engines life.
If your looking for best MPG. Good tune up. Not talking about just plugs, oil, and wires. Check your 02s out as well as your maf and other parts that dont get much love. If you can afford it dumb the cat or replace it. The 2.8/3.1 engines can get decent fuel mileage in the high 20s range when taken care of.
Old Jul 25, 2011 | 04:48 PM
Remember also that power is a function of how much air & fuel a motor takes in. With that in mind, it is very hard to mod for fuel economy and power. If you have a manual, more power will mean less downshifting, thus less fuel consumption.
It would be better in your interest to focus on subtraction. Put the car on a diet, it will be snappier and more economic. Eliminate the A/C and PS if you can live without them.
Get a high flow exhaust with headers. Get high compression pistons.
Most importantly, get a vacuum gauge. Drive with your vacuum as high as possible.
Old Jul 25, 2011 | 10:49 PM
garrison86's Avatar
iv been looking at alot of headers but i just cant figure out what one fits my set up i know im running stock right now with 3.1 but i just cant afford to buy one that dosnt fit, and the guy at autozone is no help at all lol
Old Jul 26, 2011 | 10:09 AM
djs383's Avatar
Once again, I would just do a tune up and save yourself a lot of money. It is a 20 year old V6, with most likely high(er) milage. Just enjoy what you have, to make that thing perform like a modern car will take a lot more than headers, chips, CAI, or any other easy fix out there.
